Old 10-11-2009, 12:37 AM
chickmagnet chickmagnet is offline
question on oil changes for tt
i heard from someone that you should fill the filter first with fresh oil before filling the motor with the 5 quarts (or whatever it is) on turbocharged cars. is this true?
"If it ain't broke, fix it til you are"
Old 10-11-2009, 12:46 AM
quackmandude quackmandude is offline
Re: question on oil changes for tt
ive never done that. for an na car as well as a turbo car the oil pump works the same. if seen ppl do it to othe vehicles...but mainly bigger trucks. they say its because the filters legnth so the oil can be inside it...just put the filter on, put the oil in, plug, turn the car and let it run for a bit to circulate....then check the level
SAMSUNG-SGH-I617/1.0 Mozilla/4.0 (compatible; MSIE 6.0; Windows CE; IEMobile 7.6)
Old 10-11-2009, 12:49 AM
awesome, thanks for the info. just thought id ask around before i do the change and screw something up :/
Old 10-11-2009, 04:28 AM
Dreamspawn's Avatar
Dreamspawn Dreamspawn is offline
Send a message via AIM to Dreamspawn Send a message via MSN to Dreamspawn
this is a common thing for diesels epically the trucks, from my experience as a oil and tire guy we always did this with turbo diesel trucks but never cars.
Old 10-11-2009, 09:00 AM
sLADe781 sLADe781 is offline
Really??? I used to just put the filter on with no oil in it but then I read somewhere that we should put oil in the filter so that the car isn't completely empty during start-up so I started doing that.
So which one is true? And if it's bad to have oil in the filter can someone explain why!?!
Old 10-11-2009, 10:23 AM
Girly VR-4 Girly VR-4 is offline
Yes. We always fill the oil filter with oil, and lube up the rubber seal/gasket at the top of the filter to ensure a 100% seal.
www.groundzeroperformance.com
www.3swarehouse.com
1991 Stealth R/T Twin Turbo... sitting...
1996 Orchid Pearl Stealth R/T.... daily driver duty, 275k+ miles and counting!
1995 3000GT Spyder SL... being modified...
Old 10-11-2009, 10:24 AM
Please re-read that question, then think about it.
How can it be bad, for oil to be in the oil filter?
www.3swarehouse.com
Old 10-11-2009, 10:56 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Its completely unnecessary. The oil filter fills within the first few cranks of the car.
Definitely dip your finger in some oil and rub it on the seal of the new filter before putting it on though.
Old 10-11-2009, 08:13 PM
vr4choke's Avatar
vr4choke vr4choke is offline
Send a message via AIM to vr4choke Send a message via MSN to vr4choke
ive always filled the filter on every car ive ever changed the oil on. dunno why. just seemed the right thing to do. and the walk through says too! check it
Old 10-11-2009, 08:22 PM
Stealthee's Avatar
I could make a walk thru that says to piss in your oil filter before you put it on. Doesn't mean its right and/or necessary.
Old 10-11-2009, 09:16 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
This.
Hell, my other turbo car you can't do that because the filter is at a 90 degree angle. Completely unnecessary. Just be sure to lube the gasket and you'll be fine.
Old 10-12-2009, 04:45 AM
vr4choke's Avatar
stealthee, if YOU put that in a walkthrough i would totally do it
Old 10-12-2009, 12:31 PM
lmao
Old 10-12-2009, 08:51 PM
AutostradaVR4 AutostradaVR4 is offline
Originally Posted by stealthee View Post
its completely unnecessary. The oil filter fills within the first few cranks of the car.
+3..
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
