Old 10-10-2009, 05:48 PM
93blueblazer 93blueblazer is offline
heater only works on high
i have a 99 cavalier 2.2L at trans. the blower fan for the heater only works on the highest speed. if you turn it down at all to a lower speed it just stops blowing. im not sure if it would be the switch or maybe something else. i know there is some part behind the blower fan that has to do with the fan but im not sure if it would do that. any help would be great.
Old 10-10-2009, 06:13 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: heater only works on high
Sounds like a blower motor resistor. Check for continuity between the pins on the resistor that the orange wire and the black/white wire go to. If its open than the resistor is bad. High speed bypasses the resistor and is grounded through the switch.
Old 10-11-2009, 10:06 AM
PlanetDude PlanetDude is offline
Agree with Airjer - blower resistor. I had the same problem in the sis-in-law`s 96 Cavy, and the blower resistor was the problem.
It`s in a god-awful place (at least it was on the Z24), way back behind the blower motor on the passenger side. I seem to recall taking hte blower motor out to do it, may or may not be required.
It`s a weird size socket required too. 3/16? 5/16? I can`t remember, it was over a year ago.
Good luck - if you have any questions, post back - I`ll try and help.
Mine:
89 Honda Prelude Si - 2.0, 5-speed
98 Chevy Cavalier Z24 - 2.4, auto
Family`s: (which I do the work on)
05 Chevy Impala - 3.4, auto
02 Pontiac Grand Am - 2.2, auto
01 Chevy Silverado - 5.3, auto
92 GMC Sierra - 5.7, ext cab, auto
88 Chevy Celebrity - 2.8, auto
Old 10-11-2009, 10:28 AM
Airjer_'s Avatar
Its a 5.5mm (yup a 5 and 1/2 mm socket). Sears carries them now if your looking for one.
Old 10-11-2009, 11:07 AM
Thanks.... I know it was a weird one, out of my "specialty" socket drawer... I had 5 or 6 strewn across the workbench before I found one that would work.
Mine:
