Old 04-07-2003, 10:08 AM
crvtec3 crvtec3 is offline
Running Rich....HELP!!!!
I just installed a b16 into my 90 CRX DX. I also installed a Jackson Racing Supercharger with the AEM fuel rail. I am running EXTTREMLY rich, I tries just about everything I could think of with the fuel sytem but still am getting no luck. I checked the ECU code and I think im getting a 14. What would be casueing this to run so rich? Bad injectors? not enough spark? Any help will be appriciated. thanks!
Old 04-07-2003, 10:27 AM
EF_LSVtec's Avatar
EF_LSVtec EF_LSVtec is offline
Send a message via AIM to EF_LSVtec
what kind of ecu are you using? You may want to get a Air/Fuel Controller so you can adjust mixture properly.
AF Bay Area Crew
Fully Built LSVtec Motor (245.8 whp/164.6 torque)
88 DX Hatch to JDM SiR conversion
Retired SOLD 1/08
Licensed Mortgage Consultant (Calif.)
Cellular 415.699.1797
Old 04-07-2003, 10:30 AM
im using the stock b16 ECU. are you sure a a/f controller would solve this problem?
Old 04-07-2003, 11:00 AM
EF_LSVtec's Avatar
yes it will, among other things that you need especially with a supercharger...aftermarket fuel pump, regulator and gauge. Stock PR3's fuel map is designed for a stock motor. If you can get a hold of a stage 3 or 4 hondata (programmable chip) for your pr3...it should make a world of a difference. they're quite pricey though.
AF Bay Area Crew
Retired SOLD 1/08
Old 04-07-2003, 03:02 PM
can anyone help me out a little more?
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
I would first check your oxygen sensor. When a oxygen sensor goes bad it puts the ECU into "limp mode" which cause a rich condition. The car goes into to limp mode to protect the car from getting damage from running lean. Does the car idle good ? Does hesistate any ?
Old 04-07-2003, 03:06 PM
i bought a new o2 sensor, it hesitates yes, but i cannot figure it out.
Old 04-07-2003, 03:07 PM
MAP....sounds like you need a missing link.
Old 04-07-2003, 03:08 PM
so you think my map sensor is bad?
Old 04-07-2003, 03:12 PM
No, not bad but with the JR supercharger you often need to use a "missing link". Do a search on missing link on like google and you should find all the info that you need there. I found a few good pages on it before. When the MAP sensor dosen't send the right signal to the ECU you will have the problems like what your having. VERY rich and the car will hesistate. I believe that people sell them on ebay too.
Old 04-07-2003, 04:01 PM
so does this missing link replace the map sensor or does it bolt on to it?
Old 04-07-2003, 04:07 PM
I believe that you put it inbetween the vaccum line.
Old 04-07-2003, 04:11 PM
I just emailed Synapse Engineering, the company that makes the link, and he emailed me back and said this would not correct my problem, what else could it be?
Old 04-07-2003, 04:17 PM
Does it idle rough? Maybe too high fuel pressure ?
