Old 04-07-2003, 09:30 AM
Devo2399 Devo2399 is offline
Angry Starting Problems
I've been having problems getting my van to start. Somewtimes it will fire right up, but other times it will simply click when I turn the ignition, after I turn it 20 times it starts right up. SOmetimes it takes 2 times sometimes about 50... The battery cables have been cleaned and are working fine. I'm not sure where the starter is located to check the connection, does anyone know where I can get a drawing of the engine online? PLease let em know your ideas on this problem.
Devin
Old 04-07-2003, 08:42 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
It sounds like it could be your ignition switch. It is a cheap fix and you can buy new ones from checker. Do you have an airbag? If so you will have to go to the dealreship to have it installed. If not, you can do it yourself.
Old 04-12-2003, 11:34 AM
Is there anywhere I can get a diagram of the engine? it is a 3.3L '92 Dodge Grand Caravan. I want to see if it is the starter but I am not sure where the starter is....
