Go Back   Automotive Forums Car Chat > Suzuki > Swift
Old 10-09-2009, 10:49 AM
saskguy saskguy is offline
Differential swap 2000 swift from 1991 sprint
I have a 2000 swift with an automatic transmission. The differential side bearings seem loose, 1 on the shaft, and one bearing itself is loose. I can get my hands on a 1991 sprint manual transmission cheap. Would I be so lucky that the differential from a 1991 sprint manual transmission would fit in a 2000 swift automatic transmission? A lot to ask I know but worth a shot.
Update: It works. All I had to do was change the gear on the diff. One side bearing is different also but I was changing them anyway.
Update 2: You have to modify the diff. to get the bearings the right distance apart. With a good machinist it's no problem.
