Old 10-08-2009, 08:14 PM
mad419iou1 mad419iou1 is offline
2000 Jimmy Heat and 4X4 Issue
My 2000 Jimmy vent selector is not working. Temperature control works fine, A/C works, the problem is that it doesn't matter where I turn the vent selector it blows from everywhere at once. Does anyone have any ideas on this? Also my 4 wheel drive is not working as well. I can hear the switch on the transfer case throw, and low range engages but, I have no drive on the front axle.
Mike
Old 10-08-2009, 08:36 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Re: 2000 Jimmy Heat and 4X4 Issue
Check your vacuum lines and make sure they are not cracked or torn. The climate control vent selector is vacuum controled, along with the 4x4 actuator under the battery. If both are weak then your vacuum line should be looked at carefully.
Old 10-10-2009, 11:01 AM
Found a vacuum line disconnected, and that took care of the 4WD issues.
