spring rates
ive asked this before and i got an unsatisfactory answer...
does anybody know the spring rates for the caprice? typical v8 4dr ac caprice either that or replacement spring moog part numbers? just curious because i am looking to stiffen up the ride a lot and need a starting point. my plan is to increase the rate at least 70% and keep the car mostly at the same height. if i had the funds, i might consider lowering spindles of some kind (i believe they exist for our cars) but alas, money is tight |
Re: spring rates
normal sag with the stock weak caprice springs they sag after 20,000mi...unless it has the heavy duty tow pkg springs..special order on vehicle purchase... usually most do not like how high the new HD springs set up the front end...they therefore cut down the HD springs to the desired height...when the springs are cut they get stiffer...you will find on a typical caprice the use of HD oem spec springs will raise the front end two inches because the stock standard springs are so shot.. Last edited by j cAT; 10-08-2009 at 08:15 PM. |
Re: spring rates
yeah, i know the feeling...
when i installed new shocks, the car raised up somehow... not sure why but i can only think it was because of the gas charged shocks versus the old non gas shocks... thanks |
Re: spring rates
I would like to know this too, so I can use it as a frame of reference. What would the spring rate be with base springs?
Re: spring rates
what happened with that heater problem ?
Re: spring rates
5030 is 419 lb/in assuming these are the right springs that is. also i would think those were front springs napa lists pn NCP277205 i found a moog spring chart and that spring has the same specs as moog spring pn 5428 which lists a spring rate of 393 lb/in i would say that baseline is around 350 on average. |
Re: spring rates
Re: spring rates
