Old 10-07-2009, 06:11 PM
nonewcars nonewcars is offline
92 Accord Dome Light Issue
I have a 1992 Honda Accord. The dome light did not work when I bought the car. There doesn't seem to be a fuse under the dash kick panel other than sun roof, but I don't have one, that relates to interior lights. Under the hood, there is a 15 amp interior light fuse that is not blown. I tried replacing the bulb (my god $10 for a bulb at autozone) and it still does not work. Any ideas where to look next will be appreciated.
Old 10-07-2009, 08:17 PM
mpumas mpumas is offline
Re: 92 Accord Dome Light Issue
The power that powers the powers the dome light also powers the cigarette lighter relay, so if that works, there should also be power to the dome light. The switch is on the ground side of the light and is a three position switch. Position one is off, two goes to the door switches through diodes in the safety indicator module and the third position connects to ground. So if the light doesn't work in any position check for power on one side of the bulb and ground at the third position of the switch. You will probably need a cheap voltmeter to check this.
Old 10-08-2009, 08:29 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Dome doesn't work in my wife's '95 either. Can you come fix it for me? Not worth my aggravation.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 10-08-2009, 11:29 AM
350GT 350GT is offline
there is a small part near the light that allows it to be turned on and off, and its not the switch. Dang it i forgot the name, if you use this website i think you might be able to find it
http://hondapartsnow.com
they have hot spots in their catalog, which you can pin point and choose the part from the diagram. Its a great website they even have installation guides all at your figure tips.
I guarantee you that your gonna love this website. Cheap pricing too.
Win win situation
hopes this helps
Old 10-08-2009, 12:22 PM
350GT-I looked at your site and also Majestic and can't see what you are talking about. The switch is part of the light assembly. The only other stuff is the light bulb and the lens. I haven't removed a light assembly/switch to see how the switch is mounted in the assembly but it shouldn't be rocket science.
Old 10-09-2009, 12:12 PM
how odd, for my 1991 accord it was there. You said you have checked the fuses correct??
Ok well ima try to do some research as well for this i see that your vehicle doesnt have what im talking about.
hmmm ill see what i can do and ill respond asap
Old 05-04-2010, 10:41 AM
Sorry guys. I fixed this a while back. The contacts on the light bulb were just not making good enough contact with the receptacle. After jiggling around and twisting, I got it to work.
