Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-07-2009, 05:18 PM
tex95stang tex95stang is offline
95 mustang ruuning rich - lean - no power
I just upgraded my 95 mustang 5.0 liter with a 93 cobra lower and upper intake. the stang was running well before the upgrade, now I have hesitation, sluggish, lack of power. idle goes rough. I have changed plugs, plug wires, replaced ACV, ICV, PVC, set timing. Still same issue. has anyone ran into the same problems I am having?
Old 10-08-2009, 10:23 AM
wafrederick wafrederick is offline
Banned
Re: 95 mustang ruuning rich - lean - no power
I have heard of this on a 1993 Ford f150 doing this with a 5.0 also running like a pig,it was a bad fuel presure regulator
Old 10-08-2009, 04:04 PM
I ran an ECC last night and I have two codes, one stated it was a lean on bank 1 and my egr vavle has low flow (i have elimated the egr valve). I replaced both 02 sensors since one was reading bad. I worked on it very late and will run it today to see if this fixed the problem.
Old 10-14-2009, 12:39 AM
Davescort97 Davescort97 is offline
Escort guy
Too lean on bank 1 could be a dirty MAF sensor or a vacuum leak in the intake or the PCV valve and hoses. Clean the MAF with electronics cleaner and reinstall. Disconnect the battery for 5 minutes to reset the computer so it can learn the new parameters of your upgrade.
Tags
idle , intake , mustang , rough , sluggish
