p171 p174 again!!
Anyone with any ideas?
About a year ago, the engine light came on, it was 171 and 174; I changed the isolator bolts and upper intake gaskets, but didn't change the valve cover. Last month, the light came back on, this time I bought the kit and changed everything, but noticed that the new valve cover didn't help hold back the oil from being sucked into the intake, it actually seemed worse. A day later, the light came back on. I found out that the IMRC bushings were bad; I changed those and the lower intake gaskets. Two days later, the light came back on. I already checked for other vacuum leaks and found none, externally. The only thing that I could think of is that the oil, still getting in the intake, could have messed up the new isolator bolts. I also noticed that someone on this forum mentioned something about a rocker bearing, I'm not sure what that is. I really don't want to buy that lower intake, unless I know for sure that will fix the problem.
1998 Blazer 4WD 4.3L 118,000miles 4dr Repairs--rear main seal, u/l ball joints, pitman/idler arms, i/o tie rod ends, control arm bushings, motor/trans mounts, oil relocation lines, door pin bushings, water pump, ring/pinion. --Bad ABS ground, loose connection blower motor, repaired pulse board. Mods/upgrades-Throttle plate mod. 1999 Ford Windstar SE 3.8L 160,000miles Repairs--P171/P174 procedure, loaded control arms, tie rod ends, shocks, struts, springs. |
Re: p171 p174 again!!
Could be...
Mass Airflow Sensor Fuel Pump Fuel Filter Good luck, I've had the same codes for years. |
Also, oil doesn't cause this code. Air does. So it can be the MAF sensor, fuel filter, or clogged injectors.
2003 Chevrolet Impala LS 3.8L OHV 2002 Ford Taurus SE 3.0L OHV (sold) 1998 Ford Windstar LX 3.8L OHV (sold) 2002 Chevrolet Malibu LS 3.1L OHV (sold) 2004 Hyundai Accent GS 1.6L DOHC manual (sold) 1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold) 2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold) A Windstar without having the check engine light is not a real Windstar.
