Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 10-07-2009, 06:58 AM
TN_DODGE TN_DODGE is offline
97 Ram 4x4 noise when accelerating
My 97 Ram 4x4 makes a knocking type of noise near the front/engine area when I first accelerate (actually happens just before I press the accelerator as I remove my foot from the brake).
We're talking <3 mph
It almost sounded as if I was dragging something or something (like a stick) was scraping the bottom.
Any ideas?
Old 10-07-2009, 10:21 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 97 Ram 4x4 noise when accelerating
Sounds like loose bolts on the torque converter doesn't it?
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 10-07-2009, 11:08 AM
Is that a hard (or expensive) fix?
How worried should I be?
Old 10-07-2009, 07:04 PM
AF - Advisor
I reread your 1st post again. It might be the front brakes.
If you don't work on brakes, ask around to friends & kin in your area for a good shop with a free inspection.
Old 10-26-2009, 11:06 AM
I hope it is the brakes, but it doesn't sound like the brakes. Sounds like it's coming from underneath.
Also, I crawled under the truck this weeken and saw some grease on the front axle. That might be a grease point and just some excess grease...hope its not a leak.
Old 10-26-2009, 12:35 PM
AF - Advisor
I had rust & grease on the drivers side u-joint just outside the front differential tube on my '70 GMC...it was a bad u-joint.
Old 10-26-2009, 01:15 PM
I read somewhere that it might be a grease leak at the vacuum switch (little box on axle).
Not sure if it's a big deal or not.
