Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 10-06-2009, 10:43 PM
Marnav1 Marnav1 is offline
Smile Delta 88 Turn Signal Problem
83 Delta 88 307 4 dr: Signal worked fine for probly 10 years or so. Left side quit, right side is fine. Found a bad bulb in the left rear light. Now it sometimes doesn't blink or is very slow, every 3 seconds or so. Signal light in dash lights up. I'm thinking a bad ground, the connection in the tailight seemed okay, no corrosion. Any suggestions?
Old 10-07-2009, 12:46 PM
maxwedge maxwedge is offline
A990 racer
Re: Delta 88 Turn Signal Problem
Check the socket grounds, make up a jumper to ground it seperately see what happens. or check it with an ohmeter.
Old 10-07-2009, 03:57 PM
Thanks maxwedge, can you help me locate the grounds? I'm guessing they are in the trunk area?
Old 10-07-2009, 06:31 PM
A990 racer
Probably up behind the bumper, but if is bad just make up a new one at the best location for you.
Old 10-13-2009, 03:00 PM
Checked front and back sockets. Both lights light up. I jumpered the shell of the bulb to a ground, does not flash. Right side is fine. The column switch is the problem I'm guessing. It has turn signal, wiper and cruise control. Before I disassemble I'd like to know how it comes apart. I replaced the steering wheel so I've had that off. Any pics or procedures would be helpful. Also I may have to go used, what other models will fit? I'm thinking maybe later model Cutlass or such may fit. Not many 83's around anymore.
Old 10-13-2009, 06:44 PM
A990 racer
Procedure can be found at autozone.com, repair guides, just register first.
Old 10-13-2009, 06:59 PM
Thanks.
Old 10-13-2009, 07:23 PM
inafogg inafogg is offline
make sure its not the flasher.you should be able to swap the hazard & turn signal
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
