Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 10-06-2009, 07:28 PM
jr70895 jr70895 is offline
Blower only works on super high
96 Sentra just bought the car, the fan for the A/C, heater only works on high. Any suggestions as to what the problem might be? Some folks say the blower fan switch and others say the resistor...
Thanks
Old 10-06-2009, 11:20 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Blower only works on super high
check for continuity between the pins on the resistor that the blue/black and blue/white wires go to. If its open you need a resistor. The high speed bypasses the reisitor the lower speeds use the first resistor that the power from the blower (blue/black wire) goes to. If that resistor burns out you'll loose all the lower speeds but high will still work.
Old 10-07-2009, 02:09 PM
geraldl geraldl is offline
Had the same problem on my 2001. Was the resistor board. Went to the dealer, he had one on the counter, that's how often they go. Was easy to change.
High speed works cause there is no resistance in series (maybe small current limiting) the slowest speed uses the largest resistance to limit the current going to the blower.
Old 03-04-2010, 09:58 PM
Cecils97sentra Cecils97sentra is offline
Had the same problem, it turned out to be the blower motor resistor. quick and easy to replace and not that expensive.
