Go Back   Automotive Forums Car Chat > Cadillac > STS and STS-V
Old 10-06-2009, 04:48 PM
mvestr1 mvestr1 is offline
94 STS randomly changing gears
94 STS with 4.6 liter V6. OK when cool. After warming up it randomly jumps from one gear to another when above 30 or 35 mph. It's not the converter locking and unlocking because it's jumping down to second and third also. It's not showing any trouble codes. Would appreciate any advice.
Old 10-06-2009, 06:24 PM
maxwedge maxwedge is offline
A990 racer
Re: 94 STS randomly changing gears
You need a full trans scan with a scanner set up to access the trans functions, this will point to any solenoid or slippage issues, if none a regalar scan could point to an issue with the tps.
Old 02-11-2010, 08:31 PM
M.A.C M.A.C is offline
You don't need a scanner to run diagnostics on a '94 STS because OBD I is built in. Do the following to check for trouble codes:
To enter diagnostic mode:
1. Turn ignition "ON." (Don't have to start, just turn ignition to "ON" position)
2. Depress the "OFF" and "WARMER" buttons on the Climate Control Center (CCC) simultaneously and hold until the segment check appears on the Instrument Panel Cluster (IPC).
Here is a link to the Trouble Codes List that will give you all the information you need as far as what codes mean.
http://myweb.accessus.net/~090/dtcobd1.html
