Old 10-06-2009, 02:12 PM
rlaeromech rlaeromech is offline
2003 Windstar weird transmission shifting
Hi all,
Bought a 2003 Windstar and overall I'm pleased with what I got.
Lately it feels like the transmission is acting funny and I'm not sure if its just the way its supposed to or if its a symptom of something else.
At medium to lite acceleration it goes into the last gear and then revs up slightly and then back down. Its different from the rev change you would feel if you dis-engaged the over - drive, that feels like a downshift. This is similar to what I would call a torque converter "lock-up" I think is the term.
Is this normal? or is the a symptom of something else to come.
127,000 miles. Fluid level is good and color is good.
Thanks,
Rick
Old 10-06-2009, 07:27 PM
wiswind wiswind is offline
Re: 2003 Windstar weird transmission shifting
Well.....first thing that I would want to do with a new to me windstar would be to change the transmission fluid.
The link in my signature will take you to a bunch of pictures that I have posted on webshots of various projects with my '96 windstar.
While mine is different than your 2003 in many ways, the transmission fluid change pictures will be super close to your vehicle.
Your transmission holds 12.25 quarts of transmission fluid, the correct fluid will be one that meets the Mercon V specification.
I usually get 15 quarts to do the fluid exchange....which is what I recommend you do......exchange ALL the fluid.....not just the 6 quarts that you will get if you do a pan drop and replace the fluid you get out that way.
As to the question of if there is more wrong?....that is anyone's guess.......
A transmission repair or replacement need is a common reason for a person to replace a vehicle.
HOWEVER, it IS normal for the motor to "rev up" for a moment whenever the A/C compressor kicks in.
On my '96, the only settings that do NOT have the A/C compressor cycling on and off is OFF, and VENT.
It is for SURE that your A/C will cycle in ANY setting that includes the defrost......as this helps prevent the windows from fogging over on the inside.
The motor will rev slightly whenever the compressor cycles ON.....to prevent the motor from being loaded down.
It is very possible that this is what is happening.
To see if it is.....set the climate control select to "VENT" and see if it happens.
If it does NOT....then it is just caused by the A/C cycling......and NOT a transmission problem.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 10-09-2009, 09:12 PM
mundy5 mundy5 is offline
yup, agree with wiswind; unless you know when the transmission fluid was last changed, I'd do that right away. there is a procedure in the ford service manual that allows you to change the entire amount. I believe mine came out to 15 quarts.
2003 Windstar LX
1998 4dr Civic LX
