Old 10-06-2009, 01:44 PM
kidscatsdogs kidscatsdogs is offline
Unhappy Rear wiper won't shut off
2001 dodge grand caravan rear wiper motor runs continuously and will not stop, even after we pulled the fuse. We'd just replaced the battery, but had used Coke to remove the corrosion to remove the old battery. I think we got some in the computer as I also don't have interior lights except the dash and my gauges and locks also don't work.
Old 10-06-2009, 03:00 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Rear wiper won't shut off
Go to the underhood fuse box and remove the IOD fuse for a few minutes. This will reset the Body Control Module (BCM). The BCM controls most of the electronics in the van. The Powertrain Control Module (PCM) is near the battery. The PCM is the engine's brain. The Forward Control Module is on the front of the fuse box (IPM). It controls lighting among many other things. Which did you spill coke on?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 10-06-2009, 03:56 PM
Thanks will try - just as soon as we find the IOD. Does it have another name? There's nothing listed by that name.
Old 10-06-2009, 08:55 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
IOD or Memory. On 3rd generation vans it's the fuse closest to the driver. May be the same on your 4th gen van. May have a plastic holder around it.
Any idea which computer you doused?
