Old 10-06-2009, 12:29 PM
jrshardt's Avatar
jrshardt jrshardt is offline
Unhappy 99' GTP power steering issue
The power steering goes in and out, It works most of the time on right turns.....And never on left turns, it's gradually gotten worse. It all started after a bunch of front end work and we've checked the hoses they all seem fine..Any ideas about what might be going on?
Old 10-06-2009, 09:26 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: 99' GTP power steering issue
Sounds like a rack and pinion issue to me.
By front end work you mean......?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 10-08-2009, 12:22 PM
jrshardt's Avatar
The rack and pinion's been replaced twice this year.. But it all started after the second one was put in. We've also replaced the tie rods and wheel bearings. Do you think the rack and pinion is in wrong? or a bad part?
Old 10-08-2009, 08:47 PM
tblake's Avatar
In God We Trust
NO, I doubt the rack is in wrong. Its probably bad. What brand is it? I went through 2 NAPA ones before I went and got a stock used one from an 03 GP from a salvage yard with a lifetime replacement warrenty. I hope yours is a delco and under warrenty.
Or else you could jack up the front end, remove the wheels, unhook the tir rod ends, and turn the spindles/strut assemplies by hand to feel for a binding ball joint or strut mount.
Old 10-09-2009, 08:22 AM
jrshardt's Avatar
ok we'll try that. What do you think the chances of it having variable effort steering and that being the problem, I just can't seem to find out if the 99's have them.
Old 10-09-2009, 07:42 PM
tblake's Avatar
In God We Trust
I'm pretty sure 99's is when it became standard and no longer an option. If it is an issue with the variable assist, its all intergrated with the rack.
Old 10-10-2009, 06:22 PM
jrshardt's Avatar
Thank you for the advice, we replaced the power steering pump..And stiil have the same issue looks like we'll be replacing the rack for the 3rd time...yay..ughh
Old 10-10-2009, 07:20 PM
tblake's Avatar
In God We Trust
Been there, done that. Don't do it a 4th time. Stick with stock delco replacement parts.
