clutch engage problem......
i have a 92 gmc full size ex cab 4.3L 5sp... just bought it today and everything seems to be strong only problem is the clutch don't catch till i let off the pedal just about completely.. i can just put my foot on the pedal very lightly and it starts to disengage... it shifts good.. is there an adjustment for it.. if so can someone tell me where and how to adjust it.. thanks and god bless
Re: clutch engage problem......
There is no adjustment,it is hydraulic.Could be a bad slave cylinder and the transmission does not have to come out,it is on outside
would bleeding it help with this problem or do i just need to replace.. if bleeding it will help how do i go about it.. thanks
You can try what's suggested by the others but it sounds like the clutch is done.
Time for a new clutch. |
ok that is ok but what all do i need to change i looked up clutch and it has alot of parts.. do i just change pressure plate and throw out bearing ,, etc.. let me know what is most important to change to fix this problem.. like i said it shifts fine and pulls good but just really high engage.. any info is great thanks ..
You get a kit for the clutch with a new throw out bearing,clutch and pressure plate,bearing for the input shaft which goes in the crankshaft and the line up tool.You change the pressure plate,clutch and throw out bearing.Also inspect the flywheel for hot spots,it would not hurt to get the flywheel resurfaced and any machine shop will do this.Do not get a rebuilt kit,they are a big piece of junk and you will have problems.Make sure you spray the pressure plate down with brake clean very good,has a coating to prevent rusting.
the 5 speed in those trucks do let out at the top. i have noticed it going from other cars then to my truck, it is normal. if the clutch slips then it would be time to replace it.
1993 gmc k1500 350 5spd w/od 6.5 td coming soon |
I have a '93 with the 4 speed. It didn't do that. The transmission had to come out because the clutch was so stiff it kept blowing out the master cylinder. The clutch was almost worn out, but it engaged at the normal height and felt no difference after the clutch was replaced. The stiff clutch was due to a cracked clutch fork. If the transmission needs to come out, I'd replace the fork as well.
