Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 10-04-2009, 03:38 PM
Renteria Renteria is offline
Radiator/Coolant Issue
Hello,
New to the forum...I have a 1992 Cutlass Supreme, 3.1 engine. Recently the heater hose broke (corroded). I purchased a new hose and installed without any problems. Followed mdirections from car manual to fill/replace coolant....heater works for a while then it gets cold...engine overheats....wating for a while for engine to cool, repeat process but still same results. What am I doing wrong? Is the a specific way to replace the coolant?
Regards,
Ric.
Old 10-05-2009, 05:42 AM
maxwedge maxwedge is offline
A990 racer
Re: Radiator/Coolant Issue
Welcome to AF. Did you bleed the cooling system as required?
Old 10-05-2009, 07:06 PM
Hmm...no, I have never run into something laike this...What is the required procedure for bledding the cooling system? Could anyone inform me?
Thanks in advance....
Old 10-06-2009, 07:33 AM
A990 racer
There are 2 bleeder screws one near the thermostat housing and one on the coolant pipe I believe ,you get the engine warmed up open these and wait till coolant flows in a nice stream to bleed the air, you could do a google or site search for the procedure also.
