Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 10-04-2009, 03:35 PM
montana7575 montana7575 is offline
Will 1994 rear end swap with 1990
1990 toyota pickup, 4x4, 4.10 gearing.
Machanic did'nt set preload on pinion and blew rear dif.
I found 1994 rear end same, 4x4 4.10 gear. Can I swap entire rear end?
Will this bolt up the same?
Old 10-08-2009, 09:30 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: Will 1994 rear end swap with 1990
Yes, and you don't need to swap the whole axle, just the diff.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 12-03-2009, 06:15 PM
Kyle4130 Kyle4130 is offline
86-94 and early 95s will all bolt in.
