Old 10-04-2009, 10:49 AM
koskosky koskosky is offline
Runs rough below 1/4 tank...help!!!!!
1998 cevy silverado 5.7l 350... Runs rough below 1/4 tank. I have changed the fuel fltr the truck sat in the woods for about 3 months before getting its heads rebuilt due to overheating. Thanks for the help.
Marc
Old 10-04-2009, 01:59 PM
j cAT j cAT is offline
Re: Runs rough below 1/4 tank...help!!!!!
Marc
the fuel pump gets damaged when fuel is below 1/4 level...check your fuel pressure need 60psi...also if it drops rapidly on shut down your pump is in need of replacement in most cases..
Old 10-04-2009, 09:00 PM
cramer_77 cramer_77 is offline
j cat is right, also that low in the tank your pump is gonna start sucking up dirt particles and junk like that from the bottom of the tank.
01 Silverado 2500HD, HID lows and highs, cold air kit, leveling kit, brush guard, dual flowmaster outlaw mufflers, 5% windows.
Old 10-05-2009, 05:44 PM
Thumbs up Re: Runs rough below 1/4 tank...help!!!!!
Thanks alot for the quick reply. I will try to hook up a fuel pressure gauge sometime this week. Is it a pain to change out the pump on these?
Old 10-05-2009, 09:05 PM
they aren't too hard to change, depending on how much fuel you got in the tank if you have to change out your pump. It could be easier to take the 8 bed bolts loose, filler neck, and some other wires then just set your bed back about 2 foot. but its its almost empty just drop your tank. MAKE SURE you replace the small piece of rubber hose that helps hold your pump in, i think its called the pulsator or something like that.
