Old 10-03-2009, 05:43 PM
h3llfir3 h3llfir3 is offline
How hot does styrofoam get before it gives off fumes or melts?
Question is in the title
Old 10-03-2009, 06:14 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Re: How hot does styrofoam get before it gives off fumes or melts?
Google search is a wonderful thing..
See the following link for melting point of polystyrene..
http://en.wikipedia.org/wiki/Polystyrene
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 10-04-2009, 09:07 AM
i am using it to hold a projector headlight inside the entire plastic housing. it is hanging down so i thought i could stick some styrofoam in there, the problem is that i dont want it to burn or melt because the metal projector gets very hot ( when it is on, you cannot touch it without burning your finger)..
can anyone tell me what the melting points and the points when the fumes come off of different types of styrofoam
Old 10-04-2009, 07:15 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
The styrofoam may serve as an insulator allowing the reflector housing to overheat and crack.
FWIW over the years, I have found ordinary plastics, Styrofoam etc will often melt when in extended contact with high-powered lighting. Can you use another adhesive? I have used Loctite Ultra-Copper silicone in high-heat areas such as exhaust manifolds with good success. It is engineered to be heat-resistant.
Old 10-04-2009, 10:46 PM
Arrow Re: How hot does styrofoam get before it gives off fumes or melts?
why did you say "another" adhesive lol. plastic is not an adhesive
Old 10-04-2009, 11:19 PM
MagicRat's Avatar
you are using the styrofoam to hold the light in place, hence the need for an adhesive, right?
Old 10-05-2009, 08:34 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Sytrfoam or any adhesive near a typical headlight assembly is just asking for trouble. Problems with fire could ensue shortly after dusk.
Try this...grab an infrared thermometer ($20 at the parts store) and take a temperature reading of the surfaces you intend to fix after running the lights for a while (i.e. a steady-state reading). If it can stay under about 500°F you might a have a shot with a high-temp silicone adhesive such as for exhaust applications.
There are some specialty high-temp adhesives out there, epoxy- and silicone-based that can go up to 700°F, but you'd be hard pressed to find them in the typical auto parts store. Do a little testing first to see what you're up against, then you can go and search for the best fix. Just keep in mind that sometimes it may be cheaper or alot easier to just replace the part than try to finagle a repair and hope it holds. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 10-05-2009, 09:34 PM
but the styrofoam will still burn
