Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-03-2009, 08:48 AM
hinton08 hinton08 is offline
Firefighter317
Exclamation 1987 trans am gta! Problem!
I have a 1987 Trans Am GTA 350 TPI. Recently, its been acting like it has a bad miss, but plugs, wires, cap, and rotor all are good and I have good spark. It also acts like it wants to die when you come to a stop light or something? Could it be an injector problem or what? Any suggestions would help tremendously!
Old 10-03-2009, 09:55 AM
91 bird 91 bird is offline
Re: 1987 trans am gta! Problem!
i would check the fallowing. IAC (idle air control) valve, fuel filter, and make sure all injectors are getting power. 1 injector not getting good power could cause some of those problems.
Old 10-03-2009, 10:56 AM
Firefighter317
How do you check the IAC? I know you can put a noid light on the injectors to see if its getting good pulse, and you can clean out the injectors with a pressurized injector cleaner. Low fuel pressure would be a key signal of a possible fuel filter problem right? I just need to know how to check the IAC. I have a scan tool but what should the readings be for the IAC? Thanks
Old 10-04-2009, 08:21 PM
the IAC rarely goes out. remove it and make sure there is no build up of carbon on the pintle or in the seat. that would normaly cause the stall at stops and lights.
