Old 10-02-2009, 07:45 AM
joelwideqvist joelwideqvist is offline
CFing question
Ok, I've been around long enough to know the basics of applying carbon fibre decals to complex surfaces. I'm also familiar with the Micro products. I've also read everything that I can get my hands on to get better on this part of modeling but I seem to get stuck at the same spot every time.
As a bike modeler the parts that usually get cf treatment (besides smaller stuff) is the front and rear mud guards. They are both pretty rounded but I see people cf:ing them all the time. Flawlessly. So I have here a couple of images of such a fender. To show more than write what the issue is.
First picture. I have a cf decal piece cut to shape. It has been soaked in water and MicroSet. I've slid the piece onto the part and started working it out using my fingers or a brush dipped in more MicroSet. As the shape of the fender is round I am bound to have wrinkles in the four spots that you can see on this pic.
So how do you work them out? Cause all I get is this:
I get the piece covered but there is tiny folds where the wrinkles were. And that makes the pattern look pretty bad. I shall add that before those last pics I've also used Micro Sol.
Any tip (beside "go look at the FAQ or www.justfuckinggoogleit.com) would be very appreciated.
Best regards
Joel
Old 10-02-2009, 08:32 AM
BVC500 BVC500 is offline
Re: CFing question
I haven't ventured into CFing yet, but don't have you to cut darts into CF pieces laid on rounded surfaces?
Old 10-02-2009, 09:45 AM
360spider's Avatar
Re: CFing question
I use hot towel to press the decals in place, or, where hot towel is not possible to use, hair dryer at medium heat setting. Lots of Microsol. While heating the decal, help it conform with wide brush dipped in water.
ItalianHorses.net
Old 10-02-2009, 10:32 AM
Re: CFing question
I also use a hair dryer and MicroSol, but at pretty high heat. It seems to me that I use the MicroSol when it's time to just flatten the wrinkles out. When I have come to the end of te road so to speak.
/Joel
Old 10-02-2009, 11:39 AM
racer93's Avatar
racer93 racer93 is offline
Re: CFing question
Joel,
I use a combination of several things(most times in this order)--first, Micro sol. Works like magic. Second, hair dryer. On a fender like you showed, I would use micro sol, use hair dryer, then cut along the apex of the kink and try and align the two edges so that the pattern isn't "out of line."
I have this happen all the time and this technique works well.
Daniel
Old 10-02-2009, 12:27 PM
lotus123's Avatar
lotus123 lotus123 is offline
Re: CFing question
Sounds interesting - any chance of of picture showing this technique?
Old 10-02-2009, 01:12 PM
NewTom's Avatar
NewTom NewTom is offline
Re: CFing question
/Joel
hi,
what kind of CF decal are you using???
I had trouble with SMS decals I found them a bit thick then I bought some Crazy Modeler ones and they work just perfect on surfaces like your fender
http://www.hiroboy.com/catalog/produ...oducts_id=1937
http://www.hiroboy.com/catalog/produ...oducts_id=1297
I have the extra thin version but for my fender I used the thin one and that was just fine!
http://www.hiroboy.com/catalog/produ...oducts_id=1299
good luck!
Old 10-02-2009, 01:19 PM
Decs0105's Avatar
Decs0105 Decs0105 is offline
Registered User
Re: CFing question
Well it is kinda difficult to explain but I try my best...
When you do curved parts like that you should start with brushing some Micro Set on the part then put the decal on followed by Micro Sol. To help the softening process you should heat it with the hairdryer but be careful, you will damage the CF or worse the part if it gets to hot.
It should look like the first pic you posted now. But the key is to minimize the wrinkles as much as possible because as you learned wrinkles like that won't disappear... There is a specific window for the decals (looks like you are using SMS, right?) where you are able to get the wrinkles out, if they are to dry they will settle and all you do is damage them when you touch them (the little dark spots in your pics for example could be caused by that) and on the other side if they get to soft (too much micro sol) you will damage them just as easy...
I usually try to get the wrinkles out with my fingers (stretching them, just moving them around a little bit etc.) no q-tips or anything just make sure that you finger is wet otherwise the decal will stick to it and you can start again . But that is a personal preference, some like q-tips... but I think the fingers are better because you actually "feel" what is going on.... I know it sounds stupid
So as soon as you managed to minimize these big wrinkles you should add lots of micro sol and the wrinkles will disappear. You could then again use the hair dryer to help the softening process.
When you give it a second shot, try to minimize the wrinkles with getting them out like this. I haven't done fenders like that but I think it should work out like this...
I hope that helps a bit. It is pretty much learning by doing. You should practice a bit and try out how far you can go to get the wrinkles out, you will then quickly understand what you can do with the decals and what not...
Old 10-02-2009, 02:23 PM
dlphnfn's Avatar
dlphnfn dlphnfn is offline
Re: CFing question
I agree with practice, practice, practice... Learn the limits of the decal/solution/patience.
I use MicroSol almost exclusively. MicroSet seemingly does nothing and Solvaset is too harsh for me. I brush on MSol, lay the decal on, let it work, more Sol, tap the "high spots" with a WET brush, let it work, more Sol , and keep repeating until I get the results that work for me. Those mud guards are one of the hardest surfaces in modeling to get smooth though, I think.
Erick --
WIPsBuilds
Old 10-02-2009, 02:50 PM
CrateCruncher's Avatar
CrateCruncher CrateCruncher is offline
Re: CFing question
From my experience the Micro-Sol shrinks the unrestrained parts of the decal slightly as it dries causing it to conform to the surface it's applied to. Thinner decals tend to shrink more. I've discovered it's important when conforming the decal to the shape that the decal be allowed to dry before another application. Applying MicroSol repeatedly without allowing the decal to dry will stop the conforming process.
Old 10-02-2009, 02:59 PM
Re: CFing question
Thanks New Tom and Decs0105 for your input.
Decs: So you actually use Micro Sol when you are working the wrinkles out with your finger? I thought that would just smudge the decal... I agree with you on the trial and error mode but I'm pretty much stuck in error mode right now and needed some new input.
I think the SMS cf is pretty fragile and tend to dry pretty quick, and as you say, when dry it brakes very easily.
Thanks again.
/Joel
Old 10-02-2009, 03:39 PM
Re: CFing question
Damn this live chat thing...
First, Racer 93, I missed your post. I think it hard to cut the decal at that stage. It mostly cracks. And as the surface is bent it must be impossible to line it up, or? Perhaps good enough.
Dlphnfn: Once again, I thought it would just smudge the decals if using MicroSol that way. Everywhere you read about it they say "dont touch the decal while MicroSol is working on it"...?
CrateCruncher: Ok, so you add Sol, then let it do it's job without touching the decal. When dry, just repeat?
/Joel
Old 10-02-2009, 04:21 PM
Re: CFing question
/Joel
Yes, but there is a limit to what MicroSol can do. As the stuff begins to soften the decal on the initial application I also use a stiff brush to make 4 or 5 small pleats instead of one large one. The MicroSol can more easily shrink the smaller ones.
If you are still getting wrinkles despite several MicroSol applications you may need to find thinner decals for your fenders...
Old 10-03-2009, 06:09 AM
Decs0105's Avatar
Registered User
Re: CFing question
I think the SMS cf is pretty fragile and tend to dry pretty quick, and as you say, when dry it brakes very easily...
Yes I use Micro Sol when working the wrinkles out but you don't have much time because when the magic starts (decal getting super soft ) you can't touch it anymore otherwise you will damage the decal. When you got the big ones out just apply micro sol and that will do the rest. You can also repeat that if you are not satisfied. By the way I apply micro sol with a soft brush which helps to get smaller wrinkles out while "brushing" it.
So far I haven't found anything better than the SMS decals for complex surfaces, they are really thin (and therefore fragile) and from my expierence they should be perfect for a part like that...
Old 10-03-2009, 12:04 PM
geronimo77 geronimo77 is offline
AutoWeek Magazine Vendor
Send a message via MSN to geronimo77 Send a message via Skype™ to geronimo77
Re: CFing question
Hi Joel,
Let me have some comment, maybe it will help you to have better result in the future.
That is normal what you have on your first photo, but obviously 2nd picture is not the desired outcome
What is think is you can have whatever techiuqe or method or tools, the most important thing is time. (of course only if you use good cf decal)
First of all i always make a gloss black surface before i apply CF.
than - if you use template, you should make it at least 10% bigger than to original part, it will give some treshold during application.
than - i never used MicroSol products , so i cannot comment on them, i use Mr setter and Mr softer. I apply a coat of setter to the part before i put on the decal, the a lot of softer. In the begining i use a soft flat brush.
And this is the phase where you have to spend time. when i see that the wrinkles are getting smaller and the brush is not useful anymore i use my finger. of course also wet. if the decal is soft enough you can easily get rid of the small wrinkles by streching the decal.
- I know that many people use hairdryer, but i never used so dont know in which phase it can be used.
but you can have below result with the above mentioned way
hope you can use it for next build
Gergo
