Old 10-02-2009, 06:33 AM
atjunkie atjunkie is offline
42 mpg on new rebuild?
92 1.0-Stop and go, mostly mountains around here. Can I do better?
Old 10-02-2009, 09:41 AM
quest4mpg quest4mpg is offline
Re: 42 mpg on new rebuild?
I know with new cars usually there is a break in period that the mpg isn't so good. It increases as the motor breaks in.
Old 10-02-2009, 01:07 PM
leonbentz's Avatar
leonbentz leonbentz is offline
Send a message via Yahoo to leonbentz
Sounds to me that you're doing pretty good. About the same as what I get. Mine is Automatic with air.
Old 10-02-2009, 03:07 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
That car will need at least 1000 miles for it to break in.
Old 10-04-2009, 08:00 AM
About 800 on it now Johnny. Before she went south I was getting 48mpg.
2 things that I changed were,
the egr was plugged from the exh. all the way to back of the tb. That is clean now.
And after replacing the distributor in the exact same spot as when removed, the timing was on 2btdc. Assuming the old t belt had some stretch, it may have been at 0 or some degree after??
Old 10-05-2009, 09:31 PM
Usually if the car needed a rebuild, the cat converter could be plugged up from all the carbon buildup. Just a thought.
