Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 10-01-2009, 06:52 PM
scootergirl37216's Avatar
scootergirl37216 scootergirl37216 is offline
Wink is there anyone out there to help a lady in distress?
1986 325e...her name is Blanche DuBois...and I took her in to the shop and came out with a non-functioning antenna. surely I can fix this myself, but where to start? she has always depended on the kindness of strangers...
also, where the hell is the radiator drain plug? need to refresh Blanche's fluid's 'cause she is one hot babe
thanks...Natasha
Old 11-01-2009, 08:36 AM
dark_islight's Avatar
dark_islight dark_islight is offline
Re: is there anyone out there to help a lady in distress?
Drain plug is #2 in the pictorial.
http://www.realoem.com/bmw/diagrams/r/h/18.png
Check the fuse for the antenna........
Old 12-01-2009, 08:50 AM
motorwerkes motorwerkes is offline
also the engine block drain is on the right hand side of the block above the motor mount, thirteen millimeter and twelve inch extension with an elbow, and you will be able to crack it loose, make sure you do not lose the metal gasket, when you are ready to fill remove both vents, one on the radiator hose and one on the expansion tank. when fluid starts to run out of the hose vent close it and when the fluid runs out of the expansion tank close that and make sure you have heat.
p.s. make sure you use pentison blue coolant. have fun!
Tags
1986 , 3-series , antenna , e30 , radiator
