Old 10-01-2009, 05:11 PM
franny683 franny683 is offline
2003 Windstar Tranny Problems
I have a 2003 Windstar. Drove it to work; after work went out and it wouldn't move when I shifted into gears. None of the gears work. There were no previous indicators of any problems. No grinding, no slipping, etc. Just one day out of the blue; no tranny. My question is: Is there some way to tell if the problem is something other than the tranny? Could it be the torque converter, the TRS or some other sensor? Should a repair shop be able to put it on some kind of code reader and scanner to see if there is another problem? Every place I have talked to have told me it is the transmission... when I ask them how they know, they respond that they just know. I don't want to spend $2500 without knowing for sure that's the problem and I can't make them understand this. Does anyone have any suggestions for me?
Old 10-01-2009, 09:15 PM
wiswind wiswind is offline
Re: 2003 Windstar Tranny Problems
Have you tried the other gear select postions?....R, 1, 2 ?
Do you have a Check Engine Light on?
Is the O/D light flashing?
Another thing that I have read, if the pump fails (1 mode of failure), the fluid level will check significantly high......
You check the transmission fluid level.....on level ground, motor running, Gear select in PARK.
Another test that I have read about.....to test to see if it is the TRS (Transmission Range Sensor aka Neutral Safety Switch)......With motor running (will not start with TRS unplugged).......Gear select in PARK, Unplug the electrical connection to the TRS.
The transmission 'should' still function and shift.....and be drivable....but you will have "abrupt" shifts.
This is a TEMPORARY test......to see if the TRS is causing a problem.
This will likely light the CEL and/or cause the O/D light to flash on and OFF.
Beyond these few things helping you get lucky, I cannot suggest much other than having it checked out by a reliable shop.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 10-02-2009, 09:48 AM
Thanks, we have tried it in all positions to no avail. There are no indicator lights on and the OD light is not flashing.
The fluid level checks out fine. We took it to a local garage and they changed the TRS and there is still no difference. I just thought they should be able to put it on a scope or code reader and check to see if it's throwing any codes instead of just assuming it's the transmission.
Thanks for this information.
Old 10-02-2009, 02:16 PM
bdahl385's Avatar
bdahl385 bdahl385 is offline
With the sudden complete failure of the tranny w/o any prior indications, this sure sounds electrical in nature to me. Could there be something simple like a blown fuse, bad sensor or rodent chewed wire somewhere in the electronically controlled tranny that could be the culprit?
2000 Windstar SE 3.8L 125k miles (mine)
2006 Hyundai Sonata LX 3.3L 108k miles (wife's)
2013 Hyundai Elantra GLS 21k miles (daughter)
Old 10-03-2009, 08:21 PM
mundy5 mundy5 is offline
I tend to agree with bdahl, something electrical.
2003 Windstar LX
1998 4dr Civic LX
Old 10-29-2009, 10:59 AM
joeuser742 joeuser742 is offline
If it's not too late... Drop the transmission pan and check to see if the servo tubes fell down a bit. That's one thing that would cause the no movement. If they did fall down, then there is a servo tube bracket that needs to be installed over the tubes.
1998 Blazer 4WD 4.3L 118,000miles 4dr
Repairs
--rear main seal, u/l ball joints, pitman/idler arms, i/o tie rod ends, control arm bushings, motor/trans mounts, oil relocation lines, door pin bushings, water pump, ring/pinion.
--Bad ABS ground, loose connection blower motor, repaired pulse board.
Mods/upgrades
-Throttle plate mod.
1999 Ford Windstar SE 3.8L 160,000miles
Repairs
--P171/P174 procedure, loaded control arms, tie rod ends, shocks, struts, springs.
