Old 09-30-2009, 05:39 PM
laxman21's Avatar
laxman21 laxman21 is offline
4x4 problem
99 with 4 push button selector
pushed 4 high to drive up ramps and it engaged in 4 low and is now stuck there. pushing other buttons does nothing.
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 09-30-2009, 10:55 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Re: 4x4 problem
the quickest and easiest thing to do at this point, is to disconnect the battery and leave it for a few minutes. Reconnect, start the truck and try getting it back into 4high and then to 2wd. If its flashing at this point, out the truck in reverse and a slowly reverse and see if that get it out of 4lo.
Old 10-01-2009, 03:24 PM
laxman21's Avatar
Re: 4x4 problem
Nope, not working with battery disconnect.
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 10-01-2009, 06:16 PM
4x4 blazerguy 4x4 blazerguy is offline
Re: 4x4 problem
You are trying to get it out with the trans in neutral? Have you checked the connection at the transfer case, & or is there a fuse? Just some food for thought. Mine up to now has never given me any trouble but I do use it a lot.
Old 10-01-2009, 06:43 PM
laxman21's Avatar
Re: 4x4 problem
Trans in neutral. It went into low when I pushed 4x high and I was in park or drive.
Connections are OK on case...unplugged Both and they looked fine.
When I turn the key to on, you can hear the tccm make some noise like a relay cycling.
They want 125 at the junk yard for one.
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 10-01-2009, 06:44 PM
laxman21's Avatar
Re: 4x4 problem
Any on know the part # for a new TCCM for a 99 blazer with 4 button control with auto button
15154323 on outside of box.
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 10-02-2009, 08:18 PM
laxman21's Avatar
Re: 4x4 problem
Fixed with new TCCM....well, gotta love the clunkers program...$10
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 10-02-2009, 08:53 PM
laxman21's Avatar
Re: 4x4 problem
New
Old
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 10-03-2009, 02:31 PM
Re: 4x4 problem
Glad you got it fixed.
