Old 09-30-2009, 04:58 PM
r0n1n r0n1n is offline
2003 S10 headlight dimmer switch
My highbeam indicator light stays on.
My first thought was that the high beams were on - not!
If I attempt to flip it off the head lights go out completely.
When I flip the lever again the low beams only come on,
but with the high beam indicator light on.
Is this a switch problem?
If so, does anyone know how to change out the switch?
Thanks!
Old 10-01-2009, 08:39 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2003 S10 headlight dimmer switch
Thanks!
Could be.
Check the switch for switching voltage from low to high and hight to low.
Also make sure your headlight are not burnt out on low or high and check power and ground wiring to them.
MT
Old 10-01-2009, 10:09 AM
mhilez mhilez is offline
i think yes.change swicth a new one.good luck.
