Old 09-30-2009, 03:57 PM
mudrunner80 mudrunner80 is offline
loud clunking in the front end
I have an 88 p/u 4x4 on the way home from work the front right side made a howling sound. I parked the truck for the weekend and backed up fine but when I turned it seemed to bind and clunk really bad. to the point of dragging the front tire. I had a bad boot on my cv axel so I replaced it thinking it was that and no luck. still does it. Thinking it was only on turns I tried to go forward straight and after 20' of so it clunked hard and whined as I reached 15 MPH or so. I was told hub assembly by one and the differential by another. Any advise?
Thanks
Don
Old 09-30-2009, 05:15 PM
777stickman 777stickman is offline
Re: loud clunking in the front end
If you had a bad CV boot allowing dirt and debris to get into the CV joint it's probably that.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 09-30-2009, 07:20 PM
I did replace the axle shaft and its still doing it. Were you referring to the hub assembly?
Old 10-05-2009, 07:56 AM
Chevy-SS's Avatar
Chevy-SS Chevy-SS is offline
Check CV joints carefully. Also, jack wheel up under lower a-frame, and wiggle wheel. If it has play, then probably a bad bearing. Also, check fluid in diff (drain it and fill with fresh fluid).
1968 427 Camaro SS
1998 Silverado K1500
2004 Corvette Coupe
2011 Chevy Avalanche
______________________
Old 10-05-2009, 10:56 AM
Thank you for all the help as always. It was a bad hub assembly
