Old 09-29-2009, 11:20 PM
jetboy2004's Avatar
jetboy2004 jetboy2004 is offline
Paint question
Hi guys,
I'm working on a 350Z right now and I want to make it a somewhat dark purple color. The Tamiya purple is just a bit light for me. Right now the body's been primed with Tamiya gray primer.
The question is...should I spray a few layers of black primer on top of the gray primer? (Duplicolor? What other lacquer primers are there?) Or should I spray a few layers of black paint? (Tamiya gloss or flat black?) Which way would work better?
Thanks for your help!
Old 09-29-2009, 11:54 PM
tuned.by.twenty's Avatar
tuned.by.twenty tuned.by.twenty is offline
AF Vendor-TBT's Owner
Re: Paint question
They would probably work equally well. Maybe find a plastic spoon or similar object to experiment on?
Old 09-30-2009, 12:04 AM
jetboy2004's Avatar
Re: Paint question
I did try them on plastic spoons. The one with the black primer underneath did turn out a bit darker, but still not as dark as I want it to be. Maybe I just need to spray a few more coats of purple. I did 2 or 3 coats I believe.
I was just wondering if it would make a difference between black primer and black paint.
Old 09-30-2009, 07:26 AM
ZoomZoomMX-5's Avatar
Re: Paint question
Simply using a darker primer might not be enough to get the color where you want it, especially if the color has a fair amount of pigment. You may need to find a different color or mix your own paint and airbrush, or consider a topcoat combination of transparent red and/or blue to get the color closer to your expectations.
My Fotki Album
