Lamp Control Module (LCM)
I know about the PCM, the BCM, but I just found an, "LCM" (Lamp Control Module) in my book.
What Lamps does this LCM control? Chris.
1998 Buick Park Avenue (best car GM ever made) Buick Lesabre 1997, 191,000 152,000 - Motor R.I.P. Used 111,000 Motor, All New Gaskets Used 102,000 Transmission - SOLD New Balance 662 Trek 8000 |
Re: Lamp Control Module (LCM)
Check out the wiring diagrams for your car @ AZ repair info & you can see what lights the LCM controls.
Knowledge can be communicated, but not wisdom! ![]() ![]() |
Chances are you have daytime running lamps, do you by chance have Twilight ? The LCM would control the lamps if you have that option.. It would control you exterior lamps, and automatically turn the lights on when dark..
The interior lamps would most likely be controlled by the MALL module.... IIRC your lock functions, keyless functions, Illuminated entry functions would all go through the MALL module.. |
Thank you for the reply.
No daytime running lights, or twilight (whatever that is). This helps out a lot. Thank you for sharing your knowledge. Chris.
