Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 09-29-2009, 08:08 PM
virgamanda virgamanda is offline
Send a message via AIM to virgamanda
Cruise Control Issue
I have 2003 Explorer 4.0 and just recently the cruise control began acting up. Some times it will work and other times it wont. What would cause intermittent operation. Thanks for any help.
Old 09-29-2009, 10:23 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Cruise Control Issue
when it doesn't work, does the indicator illuminate? Does it shut off while using it or just fail to turn on?
-Rod
Old 09-30-2009, 05:53 AM
-Rod
The light does not come on when not working. when it works it will stay on until you try to use it again. It never shuts off by itself while using.
Old 09-30-2009, 06:25 AM
shorod's Avatar
SHO No Mo
Other's have suggested issues with the brake light circuit causing their cruise to not even attempt to engage. Next thing to do is to make sure the brake lights work some time when the cruise doesn't.
-Rod
Old 09-30-2009, 12:50 PM
Beverly Stayart's Avatar
Beverly Stayart Beverly Stayart is offline
Thanks for this helpful info.
Old 10-01-2009, 05:36 PM
-Rod
The brake lights are continuously working while cruise control does not work. I have noticed that every morning the cruise will never work but in the afternoon on the way home from work it will work most of the time. Probably coincidence but who knows.
Old 10-01-2009, 06:45 PM
shorod's Avatar
SHO No Mo
Time for a test light, multimeter, and wiring diagram.
-Rod
