Go Back   Automotive Forums Car Chat > Nissan > Older Pickups
Old 09-29-2009, 11:56 AM
lothar5150 lothar5150 is offline
MAF sensor prob
I have a 1996 nissan hardbody 2x4 4 cylinder, It started flooding and bucking when I would give it gas. I had the codes checked. It gave a MAF sensor malfunction. I replaced with a new sensor, it made no difference it act the same as it did before. Before changing the sensor i put new plugs,wires and rotor button on it and had it timed at a local garage. Im going nuts Any ideas?
Old 10-05-2009, 10:00 AM
Re: MAF sensor prob
MAF sensor prob
Old 10-12-2009, 02:08 PM
stamar stamar is offline
Re: MAF sensor prob
does it have spark?
if not try the coil
check the fuel pressure
your maf sensor code can come on from engine flooding.
have you started it for a long time and let the gas just sit there?
sounds like a problem Ive seen come up with newer sentras
however clean that whole maf thing get the carbon out as well
ya car will start with no maf sensor at all so that wasnt likely your problem
97 sentra gxe auto 174k miles
89 nissan d21 truck z24i 213k miles ( with a cabover camper)
Old 10-13-2009, 06:24 AM
Re: MAF sensor prob
Its getting plenty of spark from the coil. I may try and return the maf sensor perhaps I got a dud. Actually it seems I am starving for gas rather than flooding. It will build RPM's until a certain point(no tach) then just drift back to idle even if i hold the gas pedal to the floor.
thanks
Eric
Old 10-14-2009, 07:12 PM
Re: MAF sensor prob
fuel pump or fuel pressure regulator
