Old 09-29-2009, 11:04 AM
kevin's van kevin's van is offline
2000 Windstar Armrest fell off
I have searched this forum finding 5-6 responses but no one addressing the correct way to reinstall the armrest on this model. The armrest has a threaded stud that screws into a nut that is welded to a bracket on the backrest of the seat. Any ideas?
Old 09-30-2009, 06:28 PM
beamrider42 beamrider42 is offline
Re: 2000 Windstar Armrest fell off
The first thing you need to do is get the threaded pivoting post out of the armrest. Look for a plastic tab where the post goes into the armrest. I think this tab pushes in against another springy metal clip that sits in a groove on the pivoting post. My pivoting post was stuck very tightly into the armrest, so tightly that I thought it wasn't meant to come out. Also, I made the mistake of trying to pull the plastic clip out, and it broke.
If the post wont turn easily in the armrest, try an appropriate lubricant, then while pushing in on the plastic tab, pull the post out of the armrest. Once the post is out, the rest was easy. Use threadlock and an allen wrench to screw the pivoting post back into the seat frame, the constant up/down motion and the stiffness is what I believe caused it fall off in the first place, it backed itself out. Then push the armrest onto the post until the metal clip re-engages the groove.
Hope this helps
Old 10-06-2009, 05:11 PM
I took the passenger side armrest off just to check. Push the plastic clip in to release the metal clip from the groove inside, while pulling the post out the armrest.
Old 10-08-2009, 02:35 PM
Beamrider,
Excellent instructions and pics. I was able to remove the threaded post within minutes of reading your post. It was difficult to see the post was removable, but once I viewed your pics everything fell into place. I have spent days on this issue. Thanks for the 110% effort to help me through this problem.
