Go Back   Automotive Forums Car Chat > Chevrolet > Lumina APV
Old 09-28-2009, 10:52 PM
rogyord rogyord is offline
pug gap???35 or 45??? 4 a 95 lumina apv with a 3.1
what is the proper spark pulg gap for a 1995 with a 3.1?? just bought this van and pulled out the AC plugs that were gapped at 35 and looked new,installed a set of autolite platnum plugs and gapped them at 45 like it says in the haynes manual,,now i have a miss at idle and a slight stumble comming off idle..it did have a slight miss at idle with the ACplugs but now its worse and the added stumble off idle,,the wires,cap and rotor look good.nice blue spark.looked for vacuum leaks and did not find any.it runs good once it gets past the stumble......thanks
Old 09-29-2009, 09:32 PM
wafrederick wafrederick is offline
Banned
Re: pug gap???35 or 45??? 4 a 95 lumina apv with a 3.1
Look on the emissions label and should say on there.General rule is to check the gap on new plugs,the gaps get crushed when shipped by truck when moving in the box
Old 10-01-2009, 04:08 PM
it does not have that label..i am thinkiing just to regap the plugs at 35...
Old 10-01-2009, 04:40 PM
Jrs3800 Jrs3800 is offline
The proper gap is .045... You may have other issues you might need to look into.. as well go back and try a set of AC Delco Plugs.. When was the last time the Wires were replaced? Looking good doesn't mean that they are good.. If the van has never had a cap and rotor it may not be a bad idea to replace those as well..
Old 10-02-2009, 04:43 PM
thank you.. i was thinking just to replace the wires, cap and rotor just to be sure...with all due respect i dont understand why i should replace the plugs with the ac delco,,,i just installed the autolites and they are gapped right...have you had bad luck with them???
Old 10-04-2009, 09:06 PM
well i replaced the cap.rotor and wires miss is gone,purrs like a kitten...now the windshield motor is acting up
