Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 09-28-2009, 07:55 PM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
Peeling clear coat
I can't remember if i posted this already but i figured i'd put it up anyway. The clear coat is peeling on the trunk lid and a little on the roof. Is there any way to fix this? Or do i have to actually repaint the whole area? Would it be as easy as buying a can of clear coat, sanding the area or something and spraying it on, maybe to at least stop it from peeling any further?
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
Old 09-28-2009, 09:06 PM
j cAT j cAT is offline
Re: Peeling clear coat
on a vehicle this old you will find the paint shops wouldn't even try to cover/repair this with out stripping..the old finish will not hold the new clear coat..I know of some owners/paint shops that will sand the damaged finish then use a self etching primer, then apply an enamel paint..this on the older vehicles holds up better ,without a complete strip job..
