Old 09-28-2009, 01:29 PM
ampig ampig is offline
Simple question
What's the secret to removing the wiper arms on a Cavalier -1995?
Old 09-28-2009, 07:03 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Simple question
Take the nut off, remove the arm from the stud. A battery terminal puller helps on some vehicles (thread the nut half way onto the stud to give the center screw a place to sit). If you can't get a puller on there, use a large flat screwdriver to pry up. With either of these methods, tapping on the side of the wiper arm with a plastic/rubber hammer (or metal if you don't care what it looks like) will help to break it loose.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 09-29-2009, 09:12 AM
Re: Simple question
Thanks. So-there's no release pin hidden that I'm not seeing.
