Old 09-28-2009, 10:29 AM
steveofwisconsin steveofwisconsin is offline
Unhappy 94 pontiac grand am 2.3l vin 3
hello, i am new to this site. Car starts up fine but after driving for a while car clunks out, but starts up again after a minute or so, then runs good for a while and clunks out again. once when it was starting to clunck out shifted to nuetral and car was reving high but still clunk out. could use some help.
Old 09-28-2009, 10:45 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: 94 pontiac grand am 2.3l vin 3
When it doesn't start what are you missing, spark or fuel?
Old 09-28-2009, 01:57 PM
I have both spark and fuel. it starts fine it quits only after engine gets hot.
Old 09-28-2009, 02:12 PM
Airjer_'s Avatar
Right, when your engine gets hot, stalls, and won't start - what are you missing Spark or fuel?
Old 09-29-2009, 10:47 AM
hi i have replaced some hoses that were badly in need from the air clearner to the oil/sir separtor to the oil pan. the spark or fuel will be hard to deteck because it starts up right after it quits. but will check and get back to you. Might take some time.
Old 09-29-2009, 11:16 AM
Airjer_'s Avatar
I guess I misunderstood you?
If you let it idle in the drive way will it stall? If you can figure out how to duplicate the symptom in the driveway it will make it a lot easier to see whats going on.
Old 09-29-2009, 01:20 PM
hi i let it idle in the driveway for 30 minutes no problem but heard clunk sound when pressing gas pedal around the 30 minutes so i turn it off. the sound does not happen before that? and then it quits shotley after.
Old 10-02-2009, 06:18 PM
inkslinger00743 inkslinger00743 is offline
Check your fuel pressure. GM fuel pumps get weak and will start to sputter out when they warm up and work fine for a while when cool. It should be at around 47-55 psi.
