Old 09-27-2009, 02:17 AM
km2002 km2002 is offline
Air in my face
I've read more than a few posts about people who get no air to their feet, but it's all coming out of their defroster. My problem is that I have almost all the air on my manual HVAC system coming out of the dash no matter what the setting is. I can set the HVAC to full defrost; I still get most of it in the face. And there's almost nothing going to the feet as well in the corresponding settings. Even if I shut down all the dash vents, the air still gets forced out around them. If the system (on a 2001 Jimmy SLE 4-dr, if that's significant) defaults to defrost with a lack of vacuum, as some posts on all-defroster problems have suggested, my problem appears to be something different. Or is it? There's also (from other posts) the question of a cheap plastic actuator that forces open the floor vent; but that wouldn't cause the air to skip the defroster in favor of the dash vents, would it? Would love to hear suggestions, especially since I get no suggestions from AllData; thanks to all.
Old 09-27-2009, 12:32 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Air in my face
Usually cased by low or no engine vacuum to heater controls.
Check for good full engine vacuum to heater controls.
Check vacuum tank if it has one and all plastic and rubber lines from engine intake to heater controls.
Is it auto AC controls or manual?
MT
Old 09-27-2009, 09:27 PM
Re: Air in my face
As I said in the original post, manual controls. Will check around the vacuum lines, thank you. That brings up something: I don't think I've ever heard the usual vacuum noises when I change the position of the control. I'm sensing a pattern.
Old 09-29-2009, 02:20 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Air in my face
The vacuum-operated diaphragm that operates the divertor door probably has a leak. If all you hear is a hissing sound when you try to change the mode, then this is probably what has happened. It takes some doing to get to it, but fortunately the dash can be loosened and pivoted back towards the seats to gain access to it. I think the part cost me about $20 from the dealer. Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
