Old 09-26-2009, 08:07 PM
getndrty getndrty is offline
2000 Jimmy - No Tach Code 340 Cam sensor
OK so I spend 6 hours pulling the intake off to replace the gasket set. Had to get the coolant out of my oil. Everything went smoothly, I marked everything even the dist Rotor location. Made sure it all went back together the way it came apart. Jimmy runs fine but I have no TACH and am tripping problem code 340 which is the cam sensor. Not sure where to look. Tried pushing on all connections didn't make any difference for the tach. Help - where do I look. Jimmy idles and runs fine so I'm thinking it just has to be a wiring glitch somewhere.
Help
Old 09-27-2009, 11:22 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2000 Jimmy - No Tach Code 340 Cam sensor
Help
Pull the cam sensor plug in and look inside the cam sensor plug for bent over terminals.
MT
