Old 09-26-2009, 07:37 PM
new2inports new2inports is offline
wiring harness
need help with harness problem.can I use my complete harness out of my 89 si in a 89 dx?both are hatch the dx good body no motor/trans. my si good motor etc bad body(rust bucket) and will be using ecm out of si.
Old 09-27-2009, 12:11 AM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Re: wiring harness
yes, you should be able to. Personally, I'd just do the mpfi swap and use the dx harness modified with parts from the si harness. There are plenty of write ups out there.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 09-27-2009, 12:54 AM
pbrizzle86 pbrizzle86 is offline
Send a message via AIM to pbrizzle86
Re: wiring harness
if by complete you mean swaping your entire harness, both engine harness and interior harness. way way way easier to add the what, 4 wires to the dx harness than mess with all the swapping
Current cars
1990 honda civic dx High Comp mini me
1986 HONDA CRX SI
Need a winter mobile....
Old 09-27-2009, 12:33 PM
4G4D Store's Avatar
Re: wiring harness
Ya, like 4-6 wires to the DX harness. 2 for injectors and 2 for distributor. I think that was it. Been a couple years since I did one of those conversions.
Old 09-27-2009, 05:17 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: wiring harness
Thats all he has to do is add the 4 wires. Use the Si harness for donor wires and connectors
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 09-27-2009, 05:27 PM
Re: wiring harness
hey guys,(wiring harness swap)
please bear with me as I am new to a wiring swap will take me a little longer.I want to get it right the first time around.I have a six wire plug on si motor but not on dx fender well.I also have a 14 wire plug on drivers side of dx and my si plug will not fit.what am I missing here guys?
Old 09-27-2009, 05:46 PM
Tony's Avatar
TLD Member #1
Re: wiring harness
http://www.automotiveforums.com/vbul...d.php?t=924146
Check that out, should answer all your questions on the wiring you need to do. You can't just swap out the engine harness and be done. Different model cars had wires running to different sides. I tried to make the walk through as simple as I could, if you have any questions after reading it, just ask.
Tony
Old 09-29-2009, 11:20 PM
Re: wiring harness
hey guys I wanted to mention that I do not have an engine harness or motor in the dx. it was bought as a shell. so I will have to use my si harness as a doner and retrive the wires needed correct?
Old 09-30-2009, 11:33 AM
Tony's Avatar
TLD Member #1
Re: wiring harness
Your best bet is to go to a salvage yard and get a DX harness, or keep on eye online for one. Otherwise you have a lot of wiring ahead of you, or swapping out the complete harness: engine and interior.
Tony
Old 10-01-2009, 11:42 PM
Re: wiring harness
help???????????what is the term cps and dizzy.
Old 10-01-2009, 11:51 PM
Re: wiring harness
oh yea let me clarify my self.I do not have a dx engine harness but do have the interior through the fire wall to fender wells on the dx>>>>now as for the si I have every thing as this car was running till I took the motor and suspention out and put it in the dx body.dx was bought as a shell:::no motor/harness.trans or drive axles.MY QUESTION? can I still use the si engine harness and take the 4/6 wires out of the si and make sure ALL wires color code match.
Old 10-02-2009, 11:58 AM
Re: wiring harness
no i dont think it would work you would have to have a bunch of conectors from the dx harness to swap over. in witch case it would be easier to just get a dx harness. if you did get it to work it would be a headache, i would assume... anyways cps is cylinder position sensor and dizzy is your distributor... honestly if you have the entire harness for the si engine and interior just swap it. its a pain in the ass but its better than what your thinking of doing in my eyes anyway
Current cars
1986 HONDA CRX SI
Old 10-02-2009, 09:30 PM
Tony's Avatar
TLD Member #1
Re: wiring harness
That is what I have said several times: the 2 options are to either get a DX engine harness and modify it, which I would highly recommend, or to swap out the DX interior harness for the Si harness.
Unless you have experience reading wiring diagrams and electrical work, swapping wires around on the Si harness to work with the DX chassis is going to be a pain in the ass and good luck with it.
Tony
Old 10-03-2009, 10:23 AM
Re: wiring harness
i know it seems like every post has been no you cant do that, and yet the hint just hasnt been taken... hahahaha
Current cars
1986 HONDA CRX SI
Old 10-04-2009, 11:46 AM
4G4D Store's Avatar
Re: wiring harness
I have a DX harness if you need one - pm me if interested.
