Old 09-26-2009, 06:38 PM
LuminaTom LuminaTom is offline
No hot electrical power!!!
I was driving along and all of a sudden I lost all my constant hot electrical. Radio, power locks, interior lights & brake lights. Horn still works though. I've checked all the fuses and they are good. Stumped on this. Any ideas would be great. Its a 1998 Lumina LS. Thanks
Old 09-26-2009, 07:13 PM
rhandwor rhandwor is offline
Re: No hot electrical power!!!
Older cars had fuse able links down by the starter. Newer vehicles have an electrical center usually near the drivers side strut. Check the relays put your finger on them and have someone else try to start. You can feel them click.
If you find one questionable try to find an other one the same size and swap.
If this is the problem buy a new relay.
Otherwise look for a damaged electrical connector in this area.
Old 09-27-2009, 09:56 PM
Checked the fusible and the relays. All look good. Any other suggestions. Thanks
Old 09-27-2009, 10:20 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
I gotta agree, it sounds like you blew a fusable link. How did you check them?
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 09-28-2009, 07:53 AM
I attached a test lamp to the wires after the link and they were both hot. Is that the way to test it or could they still be bad?
Old 09-28-2009, 12:37 PM
As long as you were on the correct side. You may have a bad ground check for power to a couple of items that don't work if you have power check the ground for these items.
Old 09-28-2009, 06:58 PM
I might have missed it, but does the car still run?
...empty gun rack.
Old 09-28-2009, 09:33 PM
Yup....runs like a top. However all the hot wires to the fuse block (inside the car) have no power. So the interior lights, power locks, power mirrors, brake lights, hazard lights and the stereo doesn't work. However the radio fuse is hot when the ignition is on. Everything else works. Headlights, heater, etc. However when I put the fan on max (4) I get nothing. I have checked every fuse over and over again but they are all good. Could it be in the ignition switch? Is there a main wire that goes to the fuse block that is constant? How can I remove the fuse panel to access the wires. Thanks
Old 09-29-2009, 01:33 AM
Bearwulf's Avatar
Bearwulf Bearwulf is offline
Have you checked the main wiring block (main connector @ firewall) & harness under dash ? There are fusible links inline of main harness as well. As previously stated CHECK ALL GROUNDS. Not all of these circuits route through the electrical center.
Bearwulf, the "howling Grizzly" of the north.
MONOTONY is the worst driving hazard, so SHUT-UP when I'm driving.
97-Lumina LS
1891Argentine 7.65 with scope!
Old 09-29-2009, 08:04 PM
Smile Re: No hot electrical power!!!
Awesome...that was it. Harness at the firewall had a bad connection. Thanks to all of you I have power again.
Old 10-25-2009, 09:38 PM
bstrom1953 bstrom1953 is offline
Hey LuminaTom, I have a 99 Lumina with the EXACT problem description right down to the list of things that quit working, while the car engine runs perfectly. I have no "hot at all times" at the fuse block. Please describe in detail where you found the bad connection. Was this a plug and socket, inside the car or on the engine side, driver side or passenger side? I have already spent 3 hours on this and can't figure out how all the orange wires (hot at all times) coming to the fuse block can be dead.
Thanks. bstrom53
Old 10-26-2009, 07:48 AM
The block is on the passengers side on the firewall right next to the alternator. It is quite hard to get off (the rubber boot on it), but when you get it off check the connectors.
Old 10-31-2009, 03:31 PM
Hey, I found the plug and socket on the firewall. The plug and socket for the heavy red wire (hot at all times wire) showed signs of arcing and excessive heat. I cleaned it up and replugged it and it worked. I also ran a backup wire through the firewall to provide hot at all times power along with it. I don't trust any plug and socket that has been that hot. I'm sure it will fail again in the future.
Old 10-31-2009, 08:10 PM
Nice catch, Bearwulf
...empty gun rack.
Old 11-01-2009, 12:43 AM
Bearwulf's Avatar
Thanks, have run across that problem twice before.
97-Lumina LS
