Old 09-26-2009, 04:59 PM
GringoPete's Avatar
GringoPete GringoPete is offline
Exclamation Has anyone used these instructions ....
.....for programming the remote entry system on a 98 Lesabre? http://answers.edmunds.com/question-...nks-33179.aspx
I know that there are intructions on here somewhere to do this but it involves jumping wires in the fuse box and i'm afraid of screwing something major up and having to replace the computer.....can someone please help me?
Old 09-26-2009, 09:26 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Has anyone used these instructions ....
Well, obviously there is a procedure HERE, but at the bottom of the instructions posted above, I also see;
© Copyright General Motors Corporation. All Rights Reserved.Source: General Motors Corporation
So evidently, it was copied from an official GM site! It could be that by holding the 'Unlock' button down during the procedure, overrides the need to jumper pins #4 & 8 on the ALDL terminal. It won't hurt to try it!
Old 09-29-2009, 07:46 PM
GringoPete's Avatar
Originally Posted by HotZ28 View Post
Well, obviously there is a procedure HERE, but at the bottom of the instructions posted above, I also see; So evidently, it was copied from an official GM site! It could be that by holding the 'Unlock' button down during the procedure, overrides the need to jumper pins #4 & 8 on the ALDL terminal. It won't hurt to try it!
Yeah, I tried the procedure from GM but it didnt work...Spent about 30 minutes trying over and over like a lunatic......Nada!
I'll try what you linked me to and see what happens....TY for your time Hotz28
Old 10-01-2009, 08:24 AM
Jrs3800 Jrs3800 is offline
With Pins 4 & 8 all your really doing is grounding out for the keyless learn sequence...
You are actually supposed to use a fused jumper wire, shame on me tho as I never have...
Old 10-01-2009, 07:29 PM
GringoPete's Avatar
I dont even kn ow what a jumper wire is and i know nothing about the fude box.......if there were like pictures or video it would probably help me out.....otherwise i'm lost
Old 10-12-2009, 12:07 AM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Just bend a paperclip into a U shape. Insert one end in 4, one end in 8.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 10-13-2009, 04:08 PM
GringoPete's Avatar
4 & 6 of what?....What am i looking for to stick a paper clip into?
The fuse box under the drivers side dash?
Old 10-14-2009, 02:57 PM
Onblsht's Avatar
Authorized Vendor
The trapezoid shaped DLC (Data Link Connector) at the bottom of your dash on the driver's side.
Old 10-14-2009, 03:23 PM
HotZ28's Avatar
AF Moderator Elite
It's not 4 & 6 It's 4 & 8 Look at pic below, this is what you are looking for. Notice the pin-out is shown upside down, because that is how you will be looking at it under the dash.
Old 10-15-2009, 07:04 AM
GringoPete's Avatar
Thumbs up Re: Has anyone used these instructions ....
This is exactly what i was looking for....correct info with illustration.....Thank You so much
