Old 09-26-2009, 05:47 PM
Dooten Dooten is offline
Cooling Fan won't shut off
The electric cooling fan on my '01 Cherokee never turns off. Cool motor or hot, the fan runs continuosly. Relay? Temp sensor? Where is the cooling fan relay located?
Old 09-26-2009, 08:34 PM
rhandwor rhandwor is offline
Re: Cooling Fan won't shut off
Look for an electrical box under the hood close to the drivers side fender.
Try swapping with another relay the same size. If this corrects the problem buy a new relay.
Look under the passenger side head light. If you search a picture is available.
Old 09-27-2009, 01:39 PM
Thanks!! The problem has gone from constant fan ON to fan NEVER comes on. I've checked the fan motor fuse it's OK. I'm pretty sure it's the relay.....just can't find it. There is no electrical box on the driver side. I moved both the evaporator cannister and the air cleaner (both on the drivers side fender) looking for the electical box or a relay. No luck. Any other suggestions?
Old 09-28-2009, 06:58 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
I couldn't locate the thread...but somewhere in here there is a thread that not only tells you where the relay is, but also how to replace it. Check the "how to" subsection also.
Let us know if you can't find it....I didn't have much time to look just now.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 09-28-2009, 08:45 AM
http://rigs.corequipment.com/cebby_W...ling.htm#relay
