Old 09-26-2009, 06:47 AM
yudyj yudyj is offline
2000 Winnie, Radiator Cap
I have a 2000 Winnie. Can not see where the radiator cap is located. Is there one ?
Old 09-26-2009, 01:42 PM
mundy5 mundy5 is offline
Re: 2000 Winnie, Radiator Cap
you are correct. there is none. it works off the reservoir only.
2003 Windstar LX
1998 4dr Civic LX
Old 09-30-2009, 08:47 PM
I want to flush water in my Radiator. My Winnie does not have a radiator cap. Does any one has a good procedure for flushing ?
Old 10-01-2009, 06:53 AM
northern piper's Avatar
northern piper northern piper is offline
the most likely way to do the flush is to open the valve at the bottom of the rad and then pull the top rad hose off. This allows the fluid to dump out and be flushed with water. Do all the safety stuff regarding capturing the waste fluid, check clamps, etc etc. I'd also pull the T-stat and replace with an OEM one, new gasket, flush the whole system. Pretty easy, although somewhat messy, job.
2000 windstar 3.8
2010 honda pilot touring
Muskoka Canada
Old 10-01-2009, 09:04 AM
veerg veerg is offline
Thank you for the advice. A couple of questions:
1) Any suggestion for where to buy the Thermostat ? Adv Auto, Auto Zone etc or the dealer
2) If I take the T-stat out, can I some how use the garden hose to flush the fluids out ? or do I fill the Rad with fresh water and run the motor for 10 mins and dump out again and repeat this many times etc ?
Old 10-01-2009, 11:05 PM
bdahl385's Avatar
bdahl385 bdahl385 is offline
A tip that is often overlooked... After flushing your system, be sure to not use regular "tap water" when filling the system back up. Either use distilled water mixed 50/50 with a quality pure antifreeze or buy the ready mixed 50/50 solution they now conveniently sell.
Too many tap water systems in the U.S. have highly mineralized and / or chemically treated water that is not good in the engine long term.
2000 Windstar SE 3.8L 125k miles (mine)
2006 Hyundai Sonata LX 3.3L 108k miles (wife's)
2013 Hyundai Elantra GLS 21k miles (daughter)
