Go Back   Automotive Forums Car Chat > Ford > E Series
E Series Forum covers questions and discussions regarding Ford E-150, Ford E-250, Ford E-350, and Ford E-450.
Old 09-25-2009, 06:09 PM
cspring cspring is offline
E-250, No Right Headlight
I have a E-250 that the headlight on the right doesn't work on low beams. High beam on that side works fine. I tried changing the light and nothing. I replaced the harness that plugs into the light cause it was corroded but still no power at the red wire ( low beam wire ). Just wondering if by some chance there is a relay or fuse that controls just the right side. By the way this model does not have DRL. Any help would be appreciated.
Old 09-25-2009, 07:05 PM
Davescort97 Davescort97 is offline
Escort guy
Re: E-250, No Right Headlight
In the fuse box in the engine compartment there should be separate fuses for left and right headlights, but since you have high beams on the right, the fuse is all right. Could have more corrosion in wiring that isn't evident at the plug. You could always run a wire from the left low beam to the right low beam. This would just provide another circuit for the low beam headlight. It wouldn't compromise your wiring system in any way. The 10 amp fuse for the left low beam is plenty of juice to operate the right also. To check the grounds on the right headlight, run a ground wire from the headlight to the battery. If the right headlight lights up, that is the problem. Hope you get it fixed. You've gotta have your headlights.
Old 09-25-2009, 09:12 PM
I already ran that wire, it works but it is still bothering me. I wish I could figure out the real problem. Thanks for the input though
Old 09-26-2009, 07:18 PM
rhandwor rhandwor is offline
You need a good wiring diagram. Look on ebay for a used one.
http://www.alldata.com/ sells a years subscription for $29.95 they have good diagrams.
