Old 09-25-2009, 09:16 AM
atjunkie atjunkie is offline
simple timing ? I hope.
On this 92 1.0 when I jumper the plug as it says to do, the marks go to 6btc and when I unplug the wire it will go to 12 or 13btc. Is this the way it should work?
Old 09-25-2009, 06:05 PM
doug7x doug7x is offline
Re: simple timing ? I hope.
yes, that's right, but you can do better...with the jumper plugged in (where you are seeing 6BTDC), loosen the distributor & turn it slightly untill you are seeing 8-10 deg. BTDC. (9 was perfect for me)...runs much better & MPG should go up 2 or 3...good luck.
Old 09-25-2009, 07:04 PM
Thanks Doug. I took her on up to 8. Now the snorkel, you guys leave them unhooked all the time or just during winter?
Old 09-25-2009, 07:13 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
I leave the snorkel off year round on both mine.
Old 09-25-2009, 10:03 PM
Yes, leave the air cleaner on, but disconnect the cold air inlet...I just pulled the hose off of the air cleaner housing. If you want to pick up a few MORE MPG, get some hose & run it from your air cleaner inlet to as close as you can get it to your exhaust manifold....you should be breathing nice, warm air all year long. Just listen for pinging under load if it gets real hot out (90 deg +)
