Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 09-24-2009, 11:11 PM
bassguitar333's Avatar
bassguitar333 bassguitar333 is offline
Send a message via MSN to bassguitar333
High Mileage
I have a 1995 CVPI. It was used in a small town, probably never used in a car chase. So, Im guessing they were, for the most part, "easy miles". It has 268,xxx miles on it. When I bought it, my dad was panicking. I know the guy before me had itr for six months, and rode the piss out of it, but he did the normal maintanence to it, and Ive done alot of maintanence, and am getting a new tranny installed next week.
How much life do you think is left in this baby? Its not knocking, burning oil, ect.
Thanks for all your help, lots of great info here.
Old 09-24-2009, 11:29 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: High Mileage
Completely depends on where it was located. In the dry states, it can easily do 300k. In the snow belt, it will not last as long due to rust from salt. By the way, although it may have not been any chases, it has probably idles alot. That is harsh on the engine, too. The oil gets hotter and the timing chain guides and tensioners wear out. The 95 timing chain guides/tensioners were tougher than the ones used in 98 and up, so you should be good even with that mileage, though.
If it's good and the body is in good condition, it may last another 100k. Additionally, since you're getting a new transmission installed, if you want some firmer shifts and elongate the life of the clutches, consider doing a J-mod on the transmission. It's relatively easy as it only requires dropping the valve body, enlarging a few holes in the separator plate, and changing/removing a few springs if desired. Cheap to do, too.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Last edited by Blue)(Fusion; 12-03-2009 at 10:38 AM. Reason: Corrected the J-Mod info
Old 09-24-2009, 11:34 PM
Re: High Mileage
Wow, thanks so much for the fast reply.
Yes, the body is in great shape, and nothing major has happened to the engine. Just small things. Valves, pulleys, ect.
Old 09-25-2009, 12:10 AM
Re: High Mileage
Well then I'd say enjoy the car. IF you do hear a noise coming from the timing cover on the front of the engine, then that would probably be the only thing that I may expect to be a problem on that car. It would sound like a sewing machine at idle and that would indicate worn timing chain guides and tensioners.
