Old 09-24-2009, 05:49 PM
joevit joevit is offline
Wheel studs
How do I remove and replace the wheel studs on my 2001 taurus? I have 4 broken ones and I can't find anything in my haynes manual. Thanks for any help.
Old 09-24-2009, 06:58 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Wheel studs
Use a hammer to beat them out. A few hits should do it. You need to remove the brakes and rotors first, or drums if it is on the rear. Then wiggle the new stud through the hub and use some washers and a nut to tighten it in until the head of the stud is secure against the back of the hub. Repeat for all studs. If you look closely, there may be a little place that is scored so you can break it out to insert the stud.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 09-26-2009, 07:21 AM
Re: Wheel studs
Thanks Way2old. Pounded the studs out yesterday. I had to jack up the other side to rotate the wheel. It had to be in one specific spot to bang out the stud. Thanks again.
